RISER x CB500X
+4
Massimo
8 participantes
RISER x CB500X Empty RISER x CB500X
Mensaje por Massimo Jue Feb 04, 2016 11:45 am
Hola chicos,
alguien ha montado
VERTICAL manillar x cb500x?
Massimo
Massimo
Fecha de inscripción : 27/02/2015
RISER x CB500X Empty Re: RISER x CB500X
Mensaje por duncanScalion Jue Feb 04, 2016 1:17 pm
umm if you used google translate... the result has been something strange. Can you explain it in english? Do you mean change the angle of the handlebar? (may my english is even worse than google tranlate!!! hehe) :P
Or maybe is easier if you insert photo or link if it is a different piece
Mensaje por Massimo Jue Feb 04, 2016 3:11 pm
el elevador, levante la mancuerna
the riser, lift the dumbbell
approaches to the pilot
It maintains the same angle
RISER x CB500X 23kp406
holy translator:D
Massimo
Massimo
Mensaje por DavidRm Jue Feb 04, 2016 4:41 pm
Ok, if I understand well... (my english is far worst than ducanScalion english), you're asking if someone mountend a hadlebar riser. If i remember well, i think no, at least in this forum. Are you looking for? maybe this can help you, its a spanish web, but 24mx.com has the same o similar models ->UNIVERSAL BAR MOUNT SPACERS
Mensaje por wozzeck Jue Feb 04, 2016 4:57 pm
Our fellow @Pelaferros uses something like that I think. These risers do not only rise the handlebar but also bring it closer to the rider. Maybe he could tell us his impressions, but afaik the only cons are that brake/clutch/throttle wires and hoses are a bit short in this bike and may be a little bit strained after installing the risers -nothing to worry about.
I've also seen some models that are adjustable in height and depth, so you can tweak the position to fit your needs.
El compi Pelaferros creo que usa algo así. Estas alzas no sólo levantan el manillar sino que lo acercan al piloto. A ver si puede contarnos qué tal le van, pero por lo que tengo entendido el único inconveniente es que en nuestra moto, los cables y mangueras de frenos, acelerador, embrague, etc van un poco justos, y al instalar las alzas quedan un poco tirantes, aunque no es nada preocupante.
También he visto otros modelos que son ajustables en altura y profundidad para que puedas dejarlos a tu gusto.
Mensaje por Pelaferros Jue Feb 04, 2016 9:44 pm
Si los llevo puestos , como bien comenta Wozzeck , los puse de 19m/m. con el fin de no variar el cableado e instalación , cortando alguna brida de plástico y modificar su anclaje por otro punto distinto , los que lleven paramanos , atento con la pantalla alta .
 También se podría acercar mas el manillar , pero la posición de los puños y manetas no se pueden , mover sobre su eje , quedando así con una posición , nada cómoda y forzada para las muñecas .
Cambia la postura con la espalda mas recta , para mi mas cómoda , creo que he acertado.
Mensaje por Beni Vie Feb 05, 2016 12:11 am
Tengo que hablar con Akira.
Se ha escacharrao algo y las letras me bailan hasta el punto de no entender nada.
Tengo que dejar el Wisky...
Mensaje por hrr500 Vie Feb 05, 2016 9:44 pm
Por cierto  Pelaferrosos dónde  se compra y qué  referencia tiene? Habrá  que  cambiar también  los tornillos supongo? Gracias
Mensaje por Pelaferros Vie Feb 05, 2016 10:27 pm
Hola hrr500 .
Es un accesorio , genérico universal lo encuentras en cualquier tienda de recambios de motos , supongo que habrá de distintas marcas , se trata de un kit completo que según la altura ya traen los tornillos a juego , puedes aprovechar la placa de apriete de HONDA o los dos puentes que te proporcionan , yo lo aproveche... .
Como no eres el primero que lo pregunta , te diré que no tiene referencia concreta , si no la de los distintos fabricantes e importadores le ponen , pero lo que tienes que matizar son las medidas , para nosotros será :diámetro 22m/m. , alto 19m/m.y lo mas importante entre centros de tornillos 34m/m. , el color lo pille de titánium .
No recuerdo el precio , pero no es caro , sino depende del hambre que pase el gitano .
Espero haberte complacido , ya comentaras como te funciona , una vez montados .
Se me olvidaba... , no tienes que desmontar ningún cable , solo alguna brida de plástico y luego lo recompones de nuevo .
Mensaje por Fox Vie Feb 05, 2016 10:32 pm
Pelaferros escribió:
No recuerdo el precio , pero no es caro , sino depende del hambre que pase el gitano ....
:jack: :jack: :jack:
